The scenario:
MicrosoftMediationServer--sip--CUBE--sip--CUCM4.2--h323--ISDN GATEWAY
There are about 100 CiscoPhones registered to CUCM4.2 and there are about 100 MOCS Clients. Both has to reach each other with the internal number and both will use the same ISDN GATEWAY to the PSTN. As the Microsoft Mediation Server only know E.164 I inserted a CUBE who can handle and add or remove the "+". The CUBE is a Cisco2821 running IOS 12.4(11)XW8 IP VOICE.
The Problem: When the MOCS Client makes external calls or calls to a CiscoPhone, it happens quite often, that there is one way audio or the call suddenly fails. Last week I exchanged the temporary CUBE with the customers one. The interesting thing is, that the temporary CUBE was also a 2821 running IOS 12.4(20)T and with this one everthing worked fine. So I tought, that there will be no problem to exchange the CUBE as I have to load the same IOS, and copy the config of the temporary one. But as soon as I had exchanged the CUBE the problems began. So I changed the IOS to
12.4(11)XW8.
Currently I'm logging a debug ccsip message and a debug ccsip call to a syslog server that I can see at the calls when the customer tell me that a probelm occured.
Any idea why these problems happens?
See below the relevant configuration of the CUBE. One thing to know is, that all the system are redundant, so there are 2 CUBE with HSRP configured.
ip cef
no ip domain lookup
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service media-renegotiate
supplementary-service ringback h225-info
h323
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice translation-rule 1
rule 1 /^\+4132326/ /0004132326/
rule 2 /^\+41/ /00041/
rule 3 /^\+/ /000/
voice translation-rule 2
rule 1 /^\00/ /+41/
rule 2 /323262998/ //
rule 3 /^\0*/ /+41/
rule 4 /^\0*/ /+41/
voice translation-rule 3
rule 1 /^\+4132326/ //
voice translation-profile FROM-MEDIATION-TO-CCM
translate calling 3
translate called 3
voice translation-profile FROM-MEDIATION-TO-ISDN
translate calling 1
translate called 1
voice translation-profile TO-MEDIATION
translate calling 2
translate called 1
voice-card 0
no dspfarm
interface GigabitEthernet0/0
ip address A.B.C.D 255.255.255.0
duplex auto
speed auto
standby 1 ip 10.105.11.78
standby 1 priority 110
ip route 0.0.0.0 0.0.0.0 A.B.C.X
dial-peer voice 7770 voip
description outbound to MEDIATION11
translation-profile outgoing TO-MEDIATION
preference 1
destination-pattern 777[0-6]
session protocol sipv2
session target ipv4:10.105.11.73
session transport tcp
dtmf-relay sip-notify
codec g711alaw
no vad
dial-peer voice 1 voip
description outbound to CCM 4.2(3) SIP
translation-profile incoming FROM-MEDIATION-TO-CCM
preference 1
destination-pattern .T
session target ipv4:172.16.1.10
incoming called-number +41323261...
dtmf-relay h245-alphanumeric
codec g711alaw
no vad
dial-peer voice 5 voip
description outbound from Mediation to ISDN
translation-profile incoming FROM-MEDIATION-TO-ISDN
preference 1
destination-pattern 000T
session target ipv4:172.16.1.5
incoming called-number +T
codec g711ulaw
no vad
dial-peer voice 8 voip
preference 1
destination-pattern 00041.........
codec g711ulaw
no vad
I am grateful for each assistance.
Peter
