IPMA on Call Manager 6.1(2)
Sep 25th, 2008
I have a manager phone that we were using to test IPMA on. Now that we are done testing I would like to use the phone for something else, however there is a little window in the bottom left corner on the LCD screen that says Assistant watch-On. I know how to turn it off & on but how do you remove the assistant watch from the LCD screen?
Brian
Overall Rating: 3 (1 ratings)
jbarcena Thu, 09/25/2008 - 12:41
  • Red, 2250 points or more
Just change the softkey template, you are using the IPMA template at this moment, so go to the phone on the CCMAdmin webpage and assign the Standard User template.
//Jorge
