Layer 3 connection to the core from access layer
Sep 25th, 2008
I want to connect my access layer switch to the core via layer 3. I did configure one of the physical port as routed port and the other end on the core. My users are coming from specific vlan like 200. I need some help on how to configure this? Apreciate your help
Here is my config:
Routed Interface config:
interface GigabitEthernet2/0/24
description "Connection to the Core"
no switchport
ip address x.x.x.x
no cdp enable
Switchport config:
switchport access vlan 200
ip route GigabitEthernet2/0/24
Overall Rating: 4 (1 ratings)
Collin Clark Thu, 09/25/2008 - 13:13
VLAN 200 would need an IP address. Let's say /24. That will be the default gateway for your user VLAN. Next you will need a static route in your Core for pointing to the IP on Gi2/0/24.
If you role this out on a larger scale, you might want to look at using a routing protocol like EIGRP and make the switch an EIGRP stub.
Hope that helps.
mrahman0302 Thu, 09/25/2008 - 13:36
Hi Collin,
Thanks for your reply. I tried that but I can not reach other network. VLAN 200 status is up but line protocol is down. I have addedd the VLAN 200 in the databse and then created SVI 200. I am using (C3750E-UNIVERSAL-M), Version 12.2(44)SE1. Any idea on that?
Jon Marshall Thu, 09/25/2008 - 14:02
You must have a port in vlan 200 that is up/up for the vlan 200 interface to show up/up.
