ACS 3.3.3 to 4..1.1 eval problems
Sep 25th, 2008
folks
i'm trying to upgrade from 3.3.3 (windows) to 4.1.1 and i get an error claiming another connection to the ACS is running, i.e. windows explorer etc but netstat shows nothing else connected
anyone has this issue before?
thanks to anyone taking the time to respond - gratefully appreciated
Overall Rating: 4 (1 ratings)
Premdeep Banga Thu, 09/25/2008 - 13:24
  • Gold, 750 points or more
The error that we are getting is generally due to huge accumulation of logs in ACS installation folder :
Please remove all the file from following location and then try ( these files are debug files, so we donot require them) :
\CSAuth\Logs
\CSRadius\Logs
\CSTacacs\Logs
\CSLog\Logs
\CSMon\Logs
\CSAdmin\Logs
\CSDbsync\Logs
Please take a backup of following folder, if auditing is required in our organization :
\Log
After taking backup of this folder, please remove logs from following location:
\Logs\AdminAudit
\Logs\Backup and Restore
\Logs\DBReplicate
\Logs\Failed Attempts
\Logs\RADIUS Accounting
\Logs\ServiceMonitoring
\Logs\TACACS+ Accounting
\Logs\TACACS+ Administration
- Stop any anitvirus software that might be running.
- Ensure that if you are using CSMARS, and you are using pnlogagent, then that service is stopped, which can be done from services.msc.
- In the end, Also make sure that Drive on which ACS is installed or intallation folder or sub-folders are not shared.
Prem
Please rate if it helps!
mulhollandm Fri, 09/26/2008 - 12:29
thanks for your help and time in replying
my problem was resolved by a reboot of the server
many thanks
