Converting traditional ACL lists to IOS firewall
Sep 25th, 2008
We are in the process of replacing our router due to obsolesence and due to the increased resource load on it over the years. We currently have an older Cisco 3640 router running IOS (C3640-I-M), Version 12.2(3), and use ACL's extensively in an attempt to prevent attacks, intrusions, etc. from entering this network. Currently it has grown to approximately 300 line items in our ACL list, so you can see that a 3640 router will no longer keep up with the traffic. We have recently purchased a Cisco3845-Sec/K9 router with advanced security S384ASK9-12403 IOS firewall package. It is currently running Cisco IOS Software, 3800 Software (C3845-ADVSECURITYK9-M), Version 12.4(3f), RELEASE SOFTWARE (fc3).
My question is if there is an easy way to take my 300 item ACL list from my old 3640 routers and convert it to a new ACL list for the 3845 router? Or should I just start from scratch? Is there any good documentation out there to get me started in the design for the firewall rules, so I can take our old 3640 list and convert it to the 3845 rule list?
Overall Rating: 4 (1 ratings)
JORGE RODRIGUEZ Sat, 09/27/2008 - 10:49
Im not aware of acl program convertions for router to router , however, I do not see a reason why you should not be able to copy and paste acls on new platform, you can attempt in cuting over the acls in groups from the old router and start building configuration on the new router.
If you have for example standard acl with 30 lines copy acl from old router in notepad for example and paste 10 lines at a time to observed weather the os takes it fully.
Rgds
Jorge
Marwan ALshawi Sat, 09/27/2008 - 18:58
hi SCOTT
i agree with jorge
howerver my suggestion is to rethink about ur ACLs redesigne it as lon as now u have IOS firewall feature which include the statefull inspection feature in the ACLs in other woords if u want http to go from in side tooutside only u dont need to make the permit ACL on the outside or the established ACL
because now u can use the CBAC features for statefull inspection and NBAR as well
in addetion to zonebaed features u could divide the IOS firewall to Zones and make it looks and works like a ASA or PIX
i would suggest you to redesign ur ACLs and security as u said u have big amount of ACLs then u need to improve it
use the following links as a guidance:
Context-Based Access Control (CBAC): Introduction and Configuration
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a0080094e8b.shtml
Three-interface Router without NAT Cisco IOS Firewall Configuration
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_configuration_example09186a0080094111.shtml
Cisco IOS Classic Firewall/IPS: Configuring Context-Based Access Control (CBAC) for Denial-of-Service Protection
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_configuration_example09186a00808b7200.shtml
Cisco IOS Firewall
Zone-Based Policy Firewall
Release 12.4(6)T
Technical Discussion
February 2006
http://www.cisco.com/en/US/prod/vpndevc/ps5708/ps5710/ps1018/prod_configuration_example0900aecd804f1776.pdf
Cisco IOS Firewall Classic and Zone-Based Virtual Firewall Application Configuration Example
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_configuration_example09186a00809492a4.shtml
now after that u can make the right config and design :)
god luck
please, if helpful Rate
