Doubt about SNA and DLSW
Sep 25th, 2008
Dear Mister
I have the next problem . We have a three routers connected to Token ring networks making DLSW . This is the configuration local to this routers :
source-bridge ring-group 150
dlsw local-peer peer-id 167.28.168.211 cost 4 promiscuous
interface TokenRing1/2
description Anillo 1480
no ip address
ring-speed 16
source-bridge 1088 3 150
source-bridge spanning
Well , I must to connect another equipment , 7200 too , and I put the next configuration , for the ring :
source-bridge ring-group 200
dlsw local-peer peer-id 167.28.190.111
dlsw remote-peer 0 tcp 10.69.1.46
interface TokenRing1/0
description "Conexion a Anillo 1088"
no ip address
load-interval 30
ring-speed 16
source-bridge 1088 10 200
In the new routers , we have another equipments and another connection ( another carrier ) .
Well , both equipment are using the same roing . The first is in the promiscuos mode , the second is with static configuration . The question is :
When I put the second equipment , the connection to the first equipment start to down .
What is the reason for this ??? The configuration is bad ???
I am new in this .
Best Regards
carenas123 Wed, 10/01/2008 - 14:44
Make sure whether the dlsw peer connection level is ok.
You can debug through sh dlsw peer
Below Document describes how to configure a router and a mainframe computer to use Systems Network Architecture Switching Services (SNASw) over Data-Link Switching (DLSw). I hope it may help you
http://www.cisco.com/en/US/tech/tk331/tk336/technologies_configuration_example09186a0080093d90.shtml#configs
mbinzer Wed, 10/01/2008 - 21:40
you are saying you have 3 routers connected to tokenring networks.
I assume you are saying 1 in the branch and 2 at the headend.
Can you clearify when you say "the first equipment start to down". Is this the dlsw peer or the dlsw circuits?
If my understanding is correct it should be the dlsw circuits. When you have a configuration like i think you have than you must configure on the headend the same virtual ring-group on both routers. you are using 150 on the promiscuous one and 200 on the other one.
In that case if both are connected to the same branch you will create problems in the dlsw reachability cache. A test frame from the branch will come to the first one, get's put on the tokenring and then forwarded back out to the branch via the second router, since they use different virtual-ring numbers they can not detect that this is not what should happen. As such the dlsw reachability cache learns the remote mac addresses local and remote and from then on you have a problem.
Try to configure i.e. 150 as virtual ring group in both. So chang the second router to
interface TokenRing 1/0
source-bridge 1088 10 150
soruce-bridge spanning
If you configure multiple routers on the same physical ring with the same ring-group number than you MUST make sure that you configure different bridge numbers in the source-bridge statement to make the rif strings unique.
In your case:
first router:
second one
Ok. If your problem is that the dlsw peer goes down to the first router when you enable the second one, than this is a different discussion.
Than it needs to be looked at what causes the peer to fail.
I would suggest to open a tac Service Request so that the issue can be propperly documented and worked to a solution.
thanks...
Matthias
