Aironet 1300 radio keeps on shutting down
Sep 25th, 2008
I have a problem with the wireless bridge connection using aironet 1300. It work fine before.no changes were done. The problem is that the radio keeps on shutting down.in the web interface radio is enabled but down. i have to manually diable it then enable it back to resolve the issue. Problem is random and this is happening on both aironet. Below is the log.
on the first aironet:
1 Mar 31 02:20:59.444 Error Interface Dot11Radio0, changed state to up
2 Mar 31 02:20:59.443 Warning Interface Dot11Radio0, Associated To AP UPAdminBridge 001e.4a05.b820 [None]
3 Mar 31 02:20:59.389 Error Interface Dot11Radio0, changed state to down
4 Mar 31 02:20:59.339 Warning Interface Dot11Radio0, parent lost: Received deauthenticate (2) not valid
5 Mar 31 01:24:51.062 Error Interface Dot11Radio0, changed state to up
6 Mar 31 01:24:51.061 Warning Interface Dot11Radio0, Associated To AP UPAdminBridge 001e.4a05.b820 [None]
on the second aironet:
1 Mar 17 09:30:42.107 Information Interface Dot11Radio0, Station UP-ASBridge 001e.f7f1.abc0 Reassociated KEY_MGMT[NONE]
2 Mar 17 09:30:41.971 Information Interface Dot11Radio0, Deauthenticating Station 001e.f7f1.abc0 Reason: Previous authentication no longer valid
3 Mar 17 09:30:41.971 Warning Packet to client 001e.f7f1.abc0 reached max retries, removing the client
regards,
Christian
didyap Wed, 10/01/2008 - 09:11
  • Silver, 250 points or more
Verify that when the radio interface is shutdown, the workstations can connect to the server immediately. Also ping from the AP to server and workstations to verify if there is any difference seen to the results seen prior to the radio interface being shut down.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
