XMedius Fax Express Edition problem
Sep 26th, 2008
I am trying to send fax the following way:
Xmedius Fax Express edition, by H.323 connected to 3845 with ISDN NT/TE vic card. I cannot send or receive fax trough this.
Here are configurations of important parts of 3845:
dial-peer voice 1 pots
max-conn 2
destination-pattern .T
port 0/1/1
dial-peer voice 4 voip
destination-pattern 16171723
translate-outgoing calling 110
translate-outgoing called 4
session target ipv4:¸5
dtmf-relay h245-signal
codec g711alaw
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
interface BRI0/1/1
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
voice-port 0/1/1
compand-type a-law
voice service pots
voice class h323 1
h225 timeout tcp establish 3
voice-card 0
no dspfarm
When I am trying to send fax, ISDN goes up, dials, and the connection is terminated. I am going directly from Fax server to VG, no CCM in between.
When I am trying to receive fax, it says that it is busy. Debug ISDN q931 is first paragraph in the attachment when I try to send fax, and when I try to receve fax, it looks like the second paragraph of the attachment.
Do you have any idea what is wrong with this?
Thank you in advance!
Best regards,
shane.orr Sat, 09/27/2008 - 18:46
I have had problems with Fax training up unless you have this command below.
1. enable
2. configure terminal
3. voice service voip
4. fax-relay sg3-to-g3
If you dont have the sg3 to g3 command available you need to update the IOS to one that supports it.
Also I am not familiar with the express edition but have had experience with the Xmedius full edition and have had to enable faststart which was a regedit.
