Cisco ASA and PAT on Same Port 1 public IP address
Sep 26th, 2008
Hi all, I need to setup Cisc ASA for PAT.
we have 1 Public IP address and 1 Server running multile sites using different ports.
From outside using internet explorer I need to access these sites using port 80
1. www.login.xyz.com
2. www.orders.xyz.com
3. www.xyz.com
inside server listening for these site using tese ports
1. www.login.xyz.com:8081
2. www.orders.xyz.com:8082
3. www.xyz.com:8083
is it possible to configure in Cisco ASA
Thanks and Regards
AFAIK - this is not possible, using the URL's to identify which server you pass the traffic onto.
If you have any spare external IP address - this is an option - specific IP address for specific web site?
If you have a content filter device behind the firewall that can redirect traffic based on URL is another options?
You could try running all the websites on the server - using virtual sites. What web servers software are you using?
HTH>
Matheenfarook Fri, 09/26/2008 - 01:46
Hi Andrew, thanks a lot for your information. we are using Apache Web server.
Best Regards
