asa 55xx multicast
Sep 26th, 2008
it was simpple auto-rp scheme with 'ip pim sparse-mode' on interconnected interfaces and all worked fine
now i put asa 5540 between corporate net and local net and turned multicast-routing on
switch with multicast listeners wrote me:
Sep 25 16:15:16 NOVST: PIM(0):Building Graft message for 239.192.99.37, GigabitEthernet1/0/18: no entries
here's switch which has multicast source
c3750#sh ip igmp groups 239.192.99.37
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last
Reporter
239.192.99.37 GigabitEthernet1/0/4 02:38:43 00:02:04 172.16.8.95
c3750#sh ip pim neighbor
PIM Neighbor Table
Neighbor Interface Uptime/Expires Ver DR
Address
Prio/Mode
172.16.251.33 GigabitEthernet1/0/24 02:38:52/00:01:34 v2 1 /
here's output from ASA:
ciscoasa# sh pim neighbor
Neighbor Address Interface Uptime Expires DR pri Bidir
1.2.3.4 7206 03:59:44 00:01:26 1 (DR)
172.16.1.248 localnet 03:59:44 00:01:39 1 (DR)
172.16.251.34 corporate 03:59:44 00:01:39 1 (DR)
switch who has listeners:
c3750-fligel#sh ip pim neighbor
PIM Neighbor Table
Address Prio/Mode
172.16.1.19 Vlan2 1d02h/00:01:40 v2 1 /
c3750-fligel#sh ip igmp groups 239.192.99.37
Group Address Interface Uptime Expires Last Reporter
239.192.99.37 Vlan2 00:00:01 00:02:58 172.16.1.189
^^ seems its a client who trying to join group.
i'd read http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807631d2.shtml
before configuring and i have upgraded 7.x sofware to 8.0(3)
if i spam `sh mroute` on asa i saw:
ciscoasa# sh mroute | i 239.192.99
(*, 239.192.99.37), 00:00:00/never, RP 0.0.0.0, flags: SPC
(*, 239.192.99.218), 00:00:00/never, RP 0.0.0.0, flags: SPC
listeners on switch with multicast source can join this group (there are 15 subdivisions connected by another switches)
seems like an ASA issue but i cant understand what i need to do to make c3750-fligel get joined.
p.s. i have 'ip pim sparse-mode' on each interface connected to ASA cause i found that sparse-dense-mode doesnt supported by ASA.
p.p.s i have 'same-security-traffic permit inter-interface
same-security-traffic permit intra-interface' options configured and localnet and corporate have same security-level
Overall Rating: 1 (2 ratings)
Moorlo Fri, 09/26/2008 - 01:17
Andrew, thank you for link i've posted before.
I'd already read this and did all that recommended.
have you read the below and made sure your config allows:-
These statements hold true for multicast traffic through the firewall:
If an access-list is applied to the interface where the multicast traffic is received, then the access control list (ACL) must explicitly permit the traffic. If no access-list is applied to the interface, the explicit ACL entry that permits the multicast traffic is not necessary.
The multicast data packets are always subjected to the Reverse Path Forwarding check of the firewall, regardless of whether the reverse-path forward check command is configured on the interface. Therefore, if there is no route on the interface that the packet was received on to the source of the multicast packet, then the packet is dropped.
If there is no route on the interface back to the source of the multicast packets, use the mroute command to instruct the firewall not to drop the packets.
HTH>
Moorlo Fri, 09/26/2008 - 01:46
yes i did read this article even before i started configuring
there are no access-lists on corporate and localnet interfaces, cause same-security-traffic permit inter-interface option enabled and these interfaces have same security-level of 100
i have ospf routing configured between asa and connected switches. packets, other than multicast pass fine.
please, tell how can i find out is there a route on the interface back to the source?
i had even put command 'mroute 172.16.8.95 255.255.255.255 corporate' but nothing changed.
