PIX 501 upgrade
Sep 26th, 2008
I have a PIX 501 running 6.3(3) a want to upgrade this firewall to version 8, like i did with my asa5510. but can not believe that version 8 will not run on a PIX 501. is that really true?
whats the latest verion for the 501 anyway?
regards
waldemar
ct,
Jon Marshall Fri, 09/26/2008 - 03:58
Unfortunately no, the pix 501 only supports pix version 6.x or earlier ie. you cannot upgrade a pix 501 or pix 506 to v7.x or beyond.
Version 6.3(5) would be the latest stable version although unless it has something you specifically need that 6.3(3) doesn't have may not be worth upgrading.
Jon
