Web-ACL for ClientLess SSL access in ASA 8,x
Sep 26th, 2008
I have a SSL Clientless VPN working for access to a citrix server farm
I would like to have some kind of access control on the traffic, and it looks like the only way is to apply an WEB-ACL on the SSL group-policy
my problem is then that the WEB-ACL only supports TCP traffic, and as the Citrix connection uses many ports, including UDP 1604, that is not working.
anyone done something similar that is working ?
Cheers
Arni
smalkeric Thu, 10/02/2008 - 11:23
  • Silver, 250 points or more
Protocols that use UDP do not work with web-ACL in clientless SSL VPN connection
