How many AnyConnect sessions?
robbhanMid
My asa 5505 has a license of 2 clientless connections and 25 VPN peers. If I'm using the AnyConnect client, how many simultaneous connections can the asa handle- Two or 25?
Thanx
andrew.prince
Level 10
Level 10
it will handle 25 - as you will be using the AnyConnect client - which is seen as a VPN peer.
HTH>
andrew.prince
Level 10
Level 10
HTH>
