site to site vpn and nat
carl_townshend
Hi all, If I have a vpn tunnel between 2 offices, but I have 1 ip the same in each office, can I nat on my firewall for this address? or will I have to do it on another device as the firewall will be doing no nat ?
7 Replies 7
andrew.prince
Level 10
Level 10
Yes - you can perform a plolicy NAT from the inside to the VPN, then encrypt from the NAT IP address on both sides.
HTH>
Hi there, can you please give me example config of this?
would you do a static nat first, then do a nat 0 on the address that its natted to ?
I would do something like this:-
SiteA
Inside host 192.168.1.1
NAT host 172.16.1.1
static (inside,outside) 172.16.1.1 access-list nat_me
access-list nat_me extended permit ip host 192.168.1.1 host 172.16.2.1
access-list no-nat extended permit ip host 172.16.1.1 host 172.16.2.1
access-list vpn-acl extended permit ip host 172.16.1.1 host 172.16.2.1
SiteB
NAT host 172.16.2.1
static (inside,outside) 172.16.2.1 access-list nat_me
access-list nat_me extended permit ip host 192.168.1.1 host 172.16.1.1
access-list no-nat extended permit ip host 172.16.2.1 host 172.16.1.1
access-list vpn-acl extended permit ip host 172.16.2.1 host 172.16.1.1
HTH>
hi there, is this the only way of doing it?
Carl,
If you have an IP address that is the SAME at both ends, yes there is another way of doing it.
You change the IP address of one end - simple eh.
If you can't change the IP address - then yes NATTING is the ONLY way to do it.
I have implemented this on so many VPN tunnels - it's just not funny. The thing is with RFC1918 addresses you WILL clash with someone at some point.
So Carl just to be clear your 2 options:-
1) NAT - you don;t have to nat on the pix/asa - you could nat on a router before the VPN devices.
2) Change IP address ranges.
HTH>
hi andrew
i didnt get this one!!
i guess if he dose nat exmption will do the job right ?!
Hey Marwan,
Yep - it works, I have implemented this more times than I care to remember. If properly implemented - it works.
