WLC and MARS 6.x
Sep 26th, 2008
1) It appears you can only add 4.x WLC's in version 5.x of MARS.
We're running WLC 5.x and some of the events are not being parsed. Can
anyone confirm that this is fixed in MARS 6.x? Can you actually add
the device as a 5.x device?
2) Does 6.x receive and correctly parse WLAN authentication success/
fail events? If so, does it map an IP address to a user?
Overall Rating: 5 (2 ratings)
jrupf Thu, 10/09/2008 - 09:07
[John] As of release 6.0.1 you must add the WLC 5.X as a 4.X device.
[John] CS-MARS supports authentication failure traps. CS-MARS does not map IP address to user.
