Clear Line does not clear a reverse telnet connection
jeffrey.girard
I have a 2511 that I use in my lab as a terminal server. Connections work great, except using the command "clear line x" does not always clear the connections. I enter the command "clear line 1" and press enter. I get the [confirm] message. I press enter. Doing a show line still shows the line as being tied up (indicated by an asterisk). I can repeat the clear line command several times with no changes. Its not all the lines, only some of them. (I have 2xoctal cables being used with 16 devices). Thoughts?
Jeff
andrew.prince
Level 10
Level 10
Jeff,
just exit out of the term server all together - it will warn you that the connected sessions will be disconnected - and they will all be dropped.
Post your config for review.
HTH>
