09-26-2008 06:58 AM - edited 03-06-2019 01:37 AM
Hi all, when we talk about rstp, we have 2 types of port edge and point to point, what is the difference between these ?
09-26-2008 07:08 AM
Hello Carl,
a point-to-point port is a port where another switch is expected (STP partner here)
an edge port = access port where an end user device is expected (no STP partner here)
It is very important to classify edge ports in order to help RSTP to achieve the fastest convergence.
Hope to help
Giuseppe
09-26-2008 07:19 AM
Hi there
So what is the difference between these ports? any spanning tree settings etc, as both ports listen and send bpdu's?
09-26-2008 07:35 AM
Hello Carl,
no BPDUs are expected on edge ports : PCs don't send them
so the portfast settings and concept can be used on edge ports.
point-to-point ports: here STP BPDUs are expected and the handshake mechanism of RSTP can used to negotiate port role and state with the neighbor
Hope to help
Giuseppe
09-26-2008 08:00 AM
In addition to above post check this link for more understanding
Hope this will help.
