Routing loop redistributing a longer prefix static route
cseymour-rhs
I have what seems a simple problem and I must be overlooking a simple solution.
Please see the attached diagram for details. I have 3 typical routers all successfully participating in a single EIGRP process. Currently, all traffic flows through the higher bandwidth connections as it should. My goal is to have all traffic from a single host A to single host B go a different route via the T1.
All this is shown in my attached diagram. I am trying to make this traffic flow change by creating a static route in Router B which is redistributed into EIGRP.
The problem is a routing loop is formed because Router C thinks that the more specific route is at Router A when it really is on its local Connected interface.
How can I have Router C ignore/overcome the more specific route to Host B and use its connected interface? I am open to a better way to make this happen, too.
I have tried a distribute-list out filter at Router A to stop the advertisement of the static route (within EIGRP). This did not work because Router C now has a route back to Router B for the more specific route. (Note: this is not indicated in the diagram)
7 Replies 7
andrew.prince
Level 10
Level 10
Your eigrp metrics are defaults - it will prefer the 100mbs every time.
Do you just want 1 host or all hosts to go over the T1?
Just the 1 host while all other traffic is unaffected.
Just as Jon has suggested - PBR is the way forward.
Jon Marshall
If you want to send just traffic for one host a different way then there are 2 easy options
1) add a static route to both A & B for the host specific route.
2)Use Policy Based Routing (PBR) on both A & B.
Note that return traffic will still go from C -> A. If you want return traffic to go back via B then you definitely need PBR.
Jon
In the end I do want return traffic to go via B so it looks like PBR is the way to go.
I am just surprised that a connected route would not override an externally learned route even if it has a more specific prefix.
Can you give me a sample of what the PBR would look like? I have not done a PBR before.
Traffic to 10.157.10.4
On router A
access-list 101 permit ip any host 10.157.10.4
route-map to-B-C permit 10
match ip address 101
set ip next-hop
int fa0/0 (interface of LAN on router A)
ip policy route-map to-B-C
On router B
route-map to-C permit 10
set ip next-hop
int fa0/0 (interface connecting router B to router A)
ip policy route-map to-C
Traffic from 10.157.10.4
On router C
access-list 101 permit host 10.157.10.4 any
route-map to-B-A permit 10
set ip next-hop
int fa0/0 (interface of LAN on router C)
ip policy route-map to-B-A
On router B
accesss-list 102 permit host 10.157.10.4 any
route-map to-A permit 10
match ip address 102
set ip next-hop
int ?? (interface connecting router B to router C)
ip policy route-map to-A
Note - I have used "any" in all the access-lists. This means that all traffic
to and from the host 10.157.10.4 will take the long path. if you want to narrow
that down to just the LAN hanging off router A replace "any" with the subnet/reverse
mask of the LAN A in the acls.
Jon
Thanks, I'll give this a try.
