Problem with ISDN Router Cisco 876
Sep 26th, 2008
Dear All i am not able to make any outgoing call from the isdn router Cisco 876.
I have used six different IOS. It gives the different result With each IOS.In most of the cases it shows outgoing calls in history instead of active. but i able to make test call on my cell and pri no.of my router. I have tried with below IOS.
c870-adventerprisek9-mz.124-15.T3
c870-adventerprisek9-mz.124-15.T4
c870-adventerprisek9-mz[1].124-11.XW9
c870-adventerprisek9-mz[1].124-20.T
c870-advipservicesk9-mz.124-9.T6.
Can you help me.
Which is suitable IOS for this Router with multicast features by which i can make outgoing call.
Giuseppe Larosa Fri, 09/26/2008 - 13:42
  • Hall of Fame,
    Founding Member
Hello Ashish,
some more information is needed in order to get better help.
Some questions:
1) what type of ISDN access are you using ?
BRI or PRI I suppose BRI is more likely available for a 876.
2) what ISDN switch type have you configured ?
3) what type of call are you meaning ?
I suppose a voice call but ISDN can be used for data with DDR so specify it.
4) may you post a filtered version of your configuration ?
From www.cisco.com/go/fn I see support for several ISDN features for the first image you have listed.
Hope to help
Giuseppe
singhashish12 Fri, 09/26/2008 - 22:17
Dear Giuseppe ,
Ans.1 I am using Bri
Ans.2 Isdn Switch type basicnet 3
Ans. 3 DATA Call. I am dialing a Prirouter to access my internal server.
Ans. 5.
Find the configuration
sh run
Building configuration...
Current configuration : 1922 bytes
version 12.4
no service pad
service password-encryption
hostname SadarBajar
boot-start-marker
boot-end-marker
no logging console
enable password 7 070A2F4D4C051C544541
no aaa new-model
ip cef
no ip domain lookup
ip multicast-routing
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
isdn switch-type basic-net3
archive
log config
hidekeys
interface BRI0
description ===Dialout(011 23548622) to PRI Delhi====
ip address 172.16.5.90 255.255.255.252
ip pim dense-mode
ip nat outside
ip virtual-reassembly
encapsulation ppp
load-interval 30
dialer string 01141377441
dialer string 01141514880
dialer string 01166309988
dialer load-threshold 3 either
isdn point-to-point-setup
dialer-group 1
ppp multilink
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
!interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.74.159.1 255.255.255.0
ip pim dense-mode
ip nat inside
ip igmp join-group 239.255.255.255
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 BRI0
no ip http server
no ip http secure-server
ip nat inside source static network 10.74.159.0 10.75.159.0 /24
dialer-list 1 protocol ip permit
control-plane
line con 0
password 7 1511021F0725
login
no modem enable
line aux 0
line vty 0 4
password 7 120D001B1C0E18557878
login
scheduler max-task-time 5000
end
SadarBajar# sh ver
Cisco IOS Software, C870 Software (C870-ADVENTERPRISEK9-M), Version 12.4(15)T3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 25-Jan-08 09:59 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
SadarBajar uptime is 2 minutes
System image file is "flash:c870-adventerprisek9-mz.124-15.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 876 (MPC8272) processor (revision 0x300) with 118784K/12288K bytes of memory.
Processor board ID FHK122628PE
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
SadarBajar#sh ip intbrief
% Invalid input detected at '^' marker.
Giuseppe Larosa Sat, 09/27/2008 - 08:01
  • Hall of Fame,
    Founding Member
Hello Ashish,
a key info is missing:
what IP address is on the remote and what ISDN number to use to reach it.
I type an example:
int BRi0
dialer map ip 172.16.5.89 01141377441
no isdn point-to-point-setup
You may need to add the broadcast option to support multicast traffic in the dialer map ip command.
Then I would configure the default static route with the IP address of the remote router
ip route 0.0.0.0 0.0.0.0 172.16.5.89
no ip route 0.0.0.0 0.0.0.0 BRI0
the BRI0 is spoofed up.
In DDR you need to provide a reason for making a call and you need to provide an exact mapping of IP address to E.164 number.
In real world scenario the interesting traffic has to be defined carefully for call charges.
I would define as interesting the traffic to the servers using the specific TCP ports.
on the remote router a return static route is needed for the LAN subnet of the 876.
Hope to help
Giuseppe
t-psallidas Thu, 11/27/2008 - 07:13
i use c870-adventerprisek9-mz.124-22.T and everything works fine
