Bug CSCsl16967
Sep 26th, 2008
Hello Folks,
How can I execute the following command from CLI in publisher:
ls -R /var/log/active/cm/cdr_repository/destination*
rm -rf /var/log/active/cm/cdr_repository/preserve/*
rm -rf /var/log/active/cm/cdr_repository/car/*
This is what I receive when trying to type the commands:
admin:rm -rf /var
Invalid command, a dash character must be preceded by an alphanumeric character
admin:
Overall Rating: 3.8 (5 ratings)
Pari Thiagasundaram Fri, 09/26/2008 - 09:14
  • Silver, 250 points or more
Have you logged in with root privileges?
This bug is fixed in 5.1.3.1106 ES patch version.
mightyking Fri, 09/26/2008 - 10:18
I have the "admin" prompt when I log into the publisher. This is all my customer has. Is the username "root"?
I see the last ES is cisco-ipt-k9-patch-es5.1.3.4101-1.tar.gz.sgn. Isn't it better for me to use the latest one? Do I need to install the ES in both Publilsher and Subscriber or only publisher will be enough?
espereir Fri, 09/26/2008 - 22:19
Hello Bahman,
The only way to execute those commands will be through root access; we have fixed that bug already; however, if upgrade is not an option please open a TAC service request and we can assist you with the workaround.
Please note that we cannot give root access/password to anyone and we will need to get access into the server through a remote session.
Hope this helps!
mightyking Mon, 09/29/2008 - 05:52
Thanks Esteban,
I don't have any problem with the upgrade but my question was the following:
Can I upgrade directely to the latest ES version available " cisco-ipt-k9-patch-es5.1.3.4101-1.tar.gz.sgn"? Or I need to go one at the time?
My second question is; do I need to install the ES only in the PUB or I have to install it in the SUP too?
bobsairam Mon, 09/29/2008 - 05:59
  • Bronze, 100 points or more
You have to install both PUB and SUB
*HTH* Pls rate IT*
Rob Huffman Mon, 09/29/2008 - 06:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi MK,
Just to add a note here to the good tips so far. The attached doc shows the installation notes and restrictions that apply to this ES;
Cisco Unified Communications Manager Engineering Special 5.1(3.4101.1)
http://www.cisco.com/web/software/282074295/21267/ESInstall5_1_3_4101-1_readme.pdf
Hope this helps!
Rob
mightyking Mon, 09/29/2008 - 06:24
Thanks Guys,
My active version is "version: 5.1.2.2000-3" and the inacive version is "Inactive Version: 5.1.2.3104-1. I don't think that I can install the ES 5.1(3.4101.1). What would be the ES that I can install to resolve the bug CSCsl16967?
How can I install the ES in the Subcriber? The only access I have is the Publisher Administratio page. How can I verify what is the latest ES installed in my CCM?
Rob Huffman Mon, 09/29/2008 - 06:37
  • Hall of Fame,
    Founding Member
Hi MK,
This Bug shows the following "fixed-in" versions;
Fixed-In
5.1(3.9901.36)
6.1(0.9901.451)
5.1(3.1106.1)
6.0(1.2115.1)
***5.1(2.3116.1)***
6.1(1.1000.11)
5.1(3.3000.1)
The problem is that this ES is not available for download only 5.1(2.3114.1) is up. I would really open up a TAC Case to see if they can post up this ES for your use.
Hope this helps!
Rob
mightyking Mon, 09/29/2008 - 06:43
Thanks Rob, I will open a case with TAC right away.
espereir Mon, 09/29/2008 - 07:41
Thanks Rob for your comments on this post and MK, go ahead and open a TAC case, we can publish the latest ES for your CUCM which already has the fix.
Just make sure that you document the exact CUCM version on the case notes ;).
HTH!
Rob Huffman Mon, 09/29/2008 - 08:02
  • Hall of Fame,
    Founding Member
Hi Esteban,
Thanks for your continued great help here! +5 points for this type of follow-up :)
Cheers!
Rob
espereir Mon, 09/29/2008 - 08:13
Thanks Rob, 5+ for helping on this post ;)
Have a nice one!
Esteban
