ROMMON in sup720-3B
Sep 26th, 2008
I have got to upgrade the IOS on catalyst 6500E, which has got 2 SUP720-3B. One of the SUP720 was working fine with the upgraded software where as the other SUP720 was booting up only in the ROMMON mode. I did access the non-working SUP720 by using (from working SUP720)the command "remote login switch" . The prompt was router-sp#.
router-sp# reload
command was issued after both the SUP720's are in the ROMMON mode and none of them are booting up the file.
I have attached the error in the file.
Any help is appreciated!
Anonymous (not verified) Sat, 09/27/2008 - 21:02
Prashanth Krishnappa Sat, 09/27/2008 - 21:09
I am suspecting there to be a typo in the file name specified in boot statement or the image to be missing. Can you issue "dir bootflash:" and "dir disk0:" and if there are any valid files you see, try issuing a manual boot(for example boot disk0:s72033-ipxxxx
