Unity Failover Question
Sep 26th, 2008
I am configuring 2 unity servers for vm only and have the primary server fully functional and I am in the process of configuring the integration on the second unity server, however I am trying to understand exactly what way it's going to work wrt licensing. I have a license for 96 ports and installed this on the primary server, however according to the installation guide you install the default license on the secondary server:
Install the default license file:
Browse to the CommServer\Licenses directory.
Double-click CiscoUnity50.lic.
This only includes a license for 2 ports. If I am to understand this, it would mean that if the primary was to fail the secondary server could only support 2 licenses, is this correct or am I completely missing something.
Thanks in advance
Paul
Overall Rating: 5 (1 ratings)
Rob Huffman Fri, 09/26/2008 - 09:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
smithsera1 Fri, 09/26/2008 - 11:04
Hi Rob,
Thanks alot for this, really clears it up for me.
Paul
