64-bit AnyConnect back to 3005?
Has anyone successfully used the new AnyConnect client to connect back to a 3005 series VPN Concentrator?
We have Vista 64-bit clients who need to connect to our pre-existing VPN networks, both a 3030 and 3005 concentrator. This is for the medical field, of course at a community hospital where just replacing the concentrator is not an option at this point...
Anyone successful at doing this yet?
hadbou Thu, 10/02/2008 - 06:22
  • Bronze, 100 points or more
The Vista version of AnyConnect (32- and 64-bit) supports everything that the Windows 2000 and Windows XP versions support, with the exception of Start Before Login. Cisco Secure Desktop, which is a distinct product from AnyConnect, provides 32-bit Vista support for its posture assessment and cache cleaner components. Cisco Secure Desktop does not support secure desktop on Vista at this time.
thomuff Wed, 01/21/2009 - 11:56
Did you get this to work with VPN Concentrators. Documentation that I have read said that AnyConnect is not supported with VPN Concentrators. If you did get it to work, how did you get it to work? I am in similiar situation.
Phillip Remaker Fri, 02/19/2010 - 11:57
  • Cisco Employee,
An official Cisco 64 bit VPN client is now in beta (5.0.7)
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
There are currently no plans to support Windows XP 64 bit in the VPN client.
