Integrating Cisco Unity Express with Call Mnager 6
Sep 26th, 2008
Can any plz let me know on how to integrate CUE woth CCM.. Mu CUE has come with licenses for CME. Do I need to change the licencse of CUE to CCM and will it work with a normal licence upgrade.
Overall Rating: 4 (1 ratings)
rob.huffman Fri, 09/26/2008 - 17:01
Hi Faizal,
You will need a new license to work with CCM;
Say your system came with a License like this for CME (Note the CME at the end of the part#);
Cisco Unified Communications Manager Express
12-mailbox package: SCUE-LIC-12CME=
What you really need is a License like this for CCM (Note the CCM at the end of the part#);
12-mailbox package: SCUE-LIC-12CCM=
You can download this license file here;
From this good doc;
Upgrading or Downgrading the Cisco Unity Express License in the Same Version
CallManager for Cisco Unity Express Configuration Example
Hope this helps!
ttrentler Thu, 11/06/2008 - 18:14
The license controls the type of integration for Unity Express. The GUI and Init wizard in Unity Express will have different options based on the license.
