Advanced Loadbalancing Decisions
Answered Question
I have some requirements from my app developers that are puzzling me. I'm not sure the ACE can do what I want, but with the flexibility of the policy and class maps I'm thinking there has to be a way.
I have a VIP that is used for two different server farms. If a user goes to the general URI http://mainwebserver.com they go to the main web serverfarm. However, if they go to http://mainwebserver.com/internal they will go to a different serverfarm.
I have this set up and working right now. Easy.
However, my application guys want to use the ACE enforce certain policies with regard to request METHODs and actions.
Example, if the user is doing a POST and they go to the mainwebserver.com URL with /internal/ and then /makechange in the URL, then they have to be using SSL. In other words, if they go to http://mainwebserver.com/internal/stuff/blah/makechange with the POST method and are coming via HTTP (as opposed to HTTPS), then I need to reject the call. If they aren't POSTing, or aren't going to /makechange, then it doesn't matter if they are using HTTP or HTTPS.
Can anyone come up with a way to accomplish this task?
Oh yeah, it's also not only /makechange, but also /getchanges combined with a POST method, that would require SSL.
Let me know if anyone needs further clarification. It looks like a fun puzzle, so have it.
Thanks!
Correct Answer by Syed Iftekhar Ahmed about 8 years 5 months ago
As per the ACE policy order Server Loadbalancing will happen first and then Inspection will take place.
Something like this should do
class-map type http inspect match-any BLOCK-HTTP
match request-method rfc post
match url
class match-all ALLOW-HTTP
match port tcp eq http
policy-map type inspect HTTP first-match PM-L7-Inspect-webserver
class BLOCK-HTTP
reset
class ALLOW-HTTP
permit
policy-map multi-match PM-BasicVIPs
class CM-webserver
loadbalance vip inservice
loadbalance policy PM-L7-webserver
loadbalance vip icmp-reply
inspect http policy PM-L7-Inspect-webserver
Try it in a test environment first.
Syed
Overall Rating: 5 (1 ratings)
Syed Iftekhar Ahmed Fri, 09/26/2008 - 10:53
With HTTP Inspection you can look for HTTP methods and Request urls and can reset the client conns if there is a match.
Something in lines with
class-map type http inspect match-all xyz
match url
policy-map type inspect http all-match HTTP_INSPECT_L7POLICY
class xyz
reset
Syed
I was thinking that the way to go would be with an INSPECT policy. But I wasn't sure how to implement it. Assuming I have a service policy of:
class CM-webserver
Would the policy action on the inspect portion and reset the connection or will it action on the loadbalance portion and service the request?
Also, the policy PM-L7-webserver is the one analyzing the URI and pushing the user to one of two serverfarms. I don't think that'll matter since the inspect class is doing the same check in the URI.
Thoughts?
Correct Answer
Syed Iftekhar Ahmed Fri, 09/26/2008 - 15:55
match url
class BLOCK-HTTP
reset
class ALLOW-HTTP
permit
class CM-webserver
Syed
