09-26-2008 10:42 AM
I'm running LMS 3.1 and I am unable to delete devices in DFM. The icon that is normally blue is greyed out.
I ran into the is issue with LMS 2.5.1 december updates but I can't recall what was done to fix this.
Any help with this is welcomed.
Thanks.
Solved! Go to Solution.
09-26-2008 12:08 PM
This is not a problem but a result of how DFM is configured. If you enable auto-management of all devices in DCR, then the delete button does not work. If you want to be able to delete devices from DFM alone, you must disable synchronization with DCR under DFM > Device Management > Device Import.
09-26-2008 12:08 PM
09-26-2008 12:17 PM
Thanks....resolved my issue.
