09-26-2008 10:57 AM - edited 03-15-2019 01:34 PM
I have a setup with 8 analog lines.All the 8 lines are configured under one trunk group.
When i try to dial outside ...the phones take too much time to dial out.
Please let me knoe if any one has a solution for this
09-26-2008 11:12 AM
It's likely that you're using a destination pattern of 9T for your dial peers. This causes the system to wait for the interdigit timeout before sending the call out. You can fix the issue by creating more specific dial peers such as:
dial-peer voice 1 pots
destination-pattern 9[2-9]......
forward-digits 7
port 0/0/0
This dial peer would allow 7 digit local calls. You can post a "show run" to verify.
Brandon
09-27-2008 12:09 AM
09-29-2008 04:35 AM
The dial peer for international calls will depend on the dial plan for your country. For example, in the US we use a dial peer similar to:
destination-pattern 9011T
prefix 011
port 0/0/0
The issue you're having with calls taking too long to complete is due to the fact that all of your dial peers with the exception of 70 end with T. This tells the system to wait for the interdigit timeout or for # before sending the call. If the dial plan for your country has variable length numbers, this may be necessary. In that case, you can press # after entering the number to cause the call to complete immediately.
Hope this helps.
Brandon
