how to check various param paramspace parameters in TCL
Sep 26th, 2008
Is there a way I can run through the script and find out which arguments it takes against param & paramspace parameters. Basically, even if I mistype any syntax router accepts it. I want to know the correct syntaxes for configuring various parameters inside TCL scripts.
I am finding it hard to keep all on my tips for my upcoming lab.
Thanks for your time...
