Secondary (Failover) Firewall not Sync-ing with Active Firewall
Sep 26th, 2008
Hello Everyone,
We have PIX-525 Active-Passive Firewall Pair. Recently, i changed the Public IP Configuration, Access Lists & NAT-ing configuration in the Active (Primary) Firewall. While doing the changes on the Active Firewall, the Secondary FW was down (powered off). We have Stateful Failover, with stateful cable connected between the serial ports of the 2 firewalls. After making the changes in Active Firewall & saving the configuration in the Active FW; i boot up the Secondary Firewall. However when i login, to the secondary FW, i can't see the new configuration. That is, the replication from the Active FW, didn't take place automatically. Can anyone through some light, as to why the secondary FW is not sync-ing with the Primary FW. Thanks in advance... Regards -- MOD
Jon Marshall Fri, 09/26/2008 - 12:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Mod
what does the ouput of a "sh failover" on both the primary and secondary look like.
What happens if you do a "write standby" on the primary ?
Jon
moditsec12 Sat, 09/27/2008 - 06:27
1) sh failover from primary:
Primary_PIX# sh failover
Failover On
Cable status: Normal
Failover unit Primary
Failover LAN Interface: N/A - Serial-based failover enabled
Unit Poll frequency 15 seconds, holdtime 45 seconds
Interface Poll frequency 5 seconds, holdtime 25 seconds
Interface Policy 1
Monitored Interfaces 8 of 250 maximum
Version: Ours 7.2(4), Mate 7.2(4)
Last Failover at: 17:34:07 AST Aug 26 2008
This host: Primary - Active
Active time: 2761620 (sec)
Interface outside (x.x.x.x): Normal (Waiting)
Interface inside (x.x.x.x): Normal (Waiting)
Interface DMZ (x.x.x.x): Normal (Waiting)
Interface DMZ2 (x.x.x.x): Normal (Waiting)
Interface DMZ3 (x.x.x.x): No Link (Waiting)
Interface WAN_DMZ (0.0.0.0): Link Down (Waiting)
Interface gb-e0 (0.0.0.0): Link Down (Waiting)
Interface gb-e1 (0.0.0.0): Link Down (Waiting)
Other host: Secondary - Sync Config
Active time: 0 (sec)
Interface outside (0.0.0.0): Unknown
Interface inside (x.x.x.x): Unknown
Interface DMZ (x.x.x.x): Unknown
Interface DMZ2 (x.x.x.x): Unknown
Interface DMZ3 (x.x.x.x): Unknown (Waiting)
Interface WAN_DMZ (0.0.0.0): Unknown (Waiting)
Interface gb-e0 (0.0.0.0): Unknown (Waiting)
Interface gb-e1 (0.0.0.0): Unknown (Waiting)
Stateful Failover Logical Update Statistics
Link : DMZ3 Ethernet4 (Failed)
Stateful Obj xmit xerr rcv rerr
General 4456494 0 0 0
sys cmd 0 0 0 0
up time 0 0 0 0
RPC services 0 0 0 0
TCP conn 590896 0 0 0
UDP conn 3865598 0 0 0
ARP tbl 0 0 0 0
Xlate_Timeout 0 0 0 0
VPN IKE upd 0 0 0 0
VPN IPSEC upd 0 0 0 0
VPN CTCP upd 0 0 0 0
VPN SDI upd 0 0 0 0
VPN DHCP upd 0 0 0 0
Logical Update Queue Information
Cur Max Total
Recv Q: 0 0 0
Xmit Q: 0 1 4456494
Primary_PIX#
moditsec12 Sat, 09/27/2008 - 06:28
2) sh failover from secondary:
pixfirewall# sh failover
Failover On
Failover unit Secondary
Interface Policy 1
Monitored Interfaces 0 of 250 maximum
Last Failover at: 13:31:36 UTC Sep 27 2008
This host: Secondary - Sync Config
Other host: Primary - Active
Active time: 2762910 (sec)
Link : DMZ3 Ethernet4 (down)
General 0 0 0 0
sys cmd 0 0 0 0
up time 0 0 0 0
TCP conn 0 0 0 0
UDP conn 0 0 0 0
ARP tbl 0 0 0 0
VPN IKE upd 0 0 0 0
VPN SDI upd 0 0 0 0
Cur Max Total
Recv Q: 0 0 0
Xmit Q: 0 0 0
pixfirewall#
pixfirewall#
Unable to sync configuration from Active
========================= NOTICE =========================
This platform is licensed to run in
failover secondary mode only
Detected an Active mate
moditsec12 Sat, 09/27/2008 - 06:29
3) Write standby on the Primary:
Primary_PIX# wr standby
Building configuration...
Config replication in progress.... Please try later
[FAILED]
in Step 2) it shows "Unable to sync configuration from Active" & in step 3) it doesnt replicate, when the "wr standby" command is given.
Thanks & Regards
MOD
netbeginner Tue, 03/03/2015 - 22:53
Dear MOD,
I am also facing the exactly same problem while excuting "Wr Standby" on active ASA.
[FAILED]
Sh failover result is also same as like you were facing. Pls guide , how you resolved this problem.
Rgds
JacquesLayman Thu, 06/04/2015 - 14:40
I'm also having the same problem. Can someone please advise as to how to for a sync between my the primary and secondary. We only powered off the primary to move it down in the rack and now it standing still by "Sync Config"
Last Failover at: 12:52:49 UTC Jan 27 2015
                Active time: 11064646 (sec)
                slot 0: ASA5525 hw/sw rev (1.0/9.1(2)) status (Up Sys)
                  Interface management (192.168.1.1): Link Down (Not-Monitored)
                  Interface RemAccess (172.18.112.2): Normal (Not-Monitored)
                  Interface outside (***.***.***.***): Normal (Not-Monitored)
                  Interface inside (172.18.24.1): Normal (Not-Monitored)
                  Interface inside-voice (172.19.32.1): Normal (Not-Monitored)
                  Interface zieto-jhb-perimeter (***.***.***.***): Normal (Not-Monitored)
                  Interface dcz-jhb-mw (***.***.***.***): Normal (Not-Monitored)
                  Interface zieto-pta-perimeter (***.***.***.***): Normal (Not-Monitored)
                  Interface dcz-pta-mw (***.***.***.***): Normal (Not-Monitored)
                  Interface dcz-pta-dmz1 (***.***.***.***): Normal (Not-Monitored)
                  Interface dr-pta-mw (***.***.***.***): Normal (Not-Monitored)
                  Interface management (0.0.0.0): Unknown (Not-Monitored)
                  Interface RemAccess (172.18.112.3): Unknown (Not-Monitored)
                  Interface outside (0.0.0.0): Unknown (Not-Monitored)
                  Interface inside (0.0.0.0): Unknown (Not-Monitored)
                  Interface inside-voice (0.0.0.0): Unknown (Not-Monitored)
                  Interface zieto-jhb-perimeter (0.0.0.0): Unknown (Not-Monitored)
                  Interface dcz-jhb-mw (0.0.0.0): Unknown (Not-Monitored)
                  Interface zieto-pta-perimeter (0.0.0.0): Unknown (Not-Monitored)
                  Interface dcz-pta-mw (0.0.0.0): Unknown (Not-Monitored)
                  Interface dcz-pta-dmz1 (0.0.0.0): Unknown (Not-Monitored)
                  Interface dr-pta-mw (0.0.0.0): Unknown (Not-Monitored)
        Link : Unconfigured.
Tushar Bangia Wed, 03/04/2015 - 21:39
All the interface shows "Normal (Waiting)", however it should show as "Normal(Monitored)". Please check the switch and cables connecting primary and standby PIX.
You can also try to disable monitoring for the "interface" for failover and than test if the failover is stable and if you are able to copy the configs.
Tushar Bangia
Note: Please do rate post if you find it helpful!!
