Stack wise or Ethernet cable makes any difference?
Answered Question
Sep 26th, 2008
Folks, can you confirm this?
I would connect both 3750A and 3750B with stackwise cable/config. I just want to confirm that in this case that would be a good idea?
Please see attached diagram.
Correct Answer by cowetacoit about 8 years 7 months ago
If you use a stacking cable it makes two or more physical switches one logical switch. Think 4500 or 6500 modular switches. each 3750 when stacked could be thought of as a line card. From your topology there should NOT be any issues. i would stack the switches because they will operate at 32gbps instead of a 1 gig ethernet link.
Overall Rating: 5 (1 ratings)
Correct Answer
cowetacoit Fri, 09/26/2008 - 12:37
