IPTV, why can't the DVR recording timers be saved.
Sep 26th, 2008
I had my Scientific Atlanta Cisco DVR router replaced 3 times already. I have 4 rooms including with HDTV on the forth. If my DVR has to be replaced for the 4th time, is there anyway to save the DVR recording timers. Isn't what the USB port is for? Is it possible to back up the DVR recording timers to the USB port before replacing the DVR again. I set the DVR recording timers to more than 10 shows on the DVR. My wife been with at&t technical support trying to fix the Filipino channel on the HDTV tv and they can't fix it. The Filipino Channel runs ok with the other 3 TV's.
