Pre-Shared key
Sep 27th, 2008
Hi All,
i just have a quick quest.
what are the characters that i can use in my Pre-Shared key to establish VPN tunnel? i'm wondering can i use the following characters: ! @ # $ _
Thanks in advance...
Hi, I just experienced a problem the may be related to these special characters. I didn't test fully so take this advice with a bit of caution: Under ASA 7.23 OS and possible other OS versions, using special characters in keys causes the key to become deformed, or invalid (don't know which). I upgraded to OS 8.X, re-entered the pre-shared key with special characters and it worked.
