Warning message
3750G Switch Configuration
Sep 27th, 2008
Greetings,
I have a 3750G switch with one port which has been problematic. Directly plugged into the port is a sonos network music device. This device has a switchport into which a windows client machine is plugged. Both are on the same vlan. Periodically the windows client machine loses connectivity to the network and I need to shut/no shut the port to restore connectivity. Here is the output from a show int command:
sw3750#show int Gi1/0/28
GigabitEthernet1/0/28 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0018.7393.4a9c (bia 0018.7393.4a9c)
Description: Patch port 2-13 to Entertainment Deckhouse
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:01:11, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 6000 bits/sec, 4 packets/sec
5 minute output rate 3000 bits/sec, 5 packets/sec
54426018 packets input, 371714906 bytes, 0 no buffer
Received 1018760 broadcasts (0 multicast)
0 runts, 2 giants, 0 throttles
11065 input errors, 5413 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 786806 multicast, 0 pause input
102805071 packets output, 3751710977 bytes, 0 underruns
0 output errors, 0 collisions, 17 interface resets
sw3750#
The port is configured as follows:
interface GigabitEthernet1/0/28
description Patch port 2-13 to Entertainment Deckhouse
switchport access vlan 30
switchport mode access
power inline never
no mdix auto
no cdp enable
spanning-tree portfast
My questions are:
-Is this port configuration correct given that I need to have more than 1 device connectd to this port?
-What other commands can I use to troubleshoot the errors on the port?
TIA
Charlie
Giuseppe Larosa Sat, 09/27/2008 - 08:38
  • Hall of Fame,
    Founding Member
Hello Charlie,
you should look at the logging buffer for log messages about the port.
the configuration is correct: without port security the number of mac addresses is not a problem.
However, the port is set for STP portfast.
try to use
show spanning-tree interface g1/0/28 and look for spanning-tree bpdu guard
With BPDU guard enabled if a BPDU is heard on the interface the interface is placed in errordisable and you need to do sh/ no sh.
It is possible to associate the bdu guard to ports in portfast in global config.
I see that there are input errors:
are these errors incrementing over time or not ?
Feel free to post ouput of sh spanning-tree int gi1/0/28 and from log
use for log to filter messages:
sh log | inc 1/0/28
Hope to help
Giuseppe
IM-Design Sat, 09/27/2008 - 08:48
Hi Guiseppe,
Thanks for the reply.
Here is the output from those 2 commands:
sw3750#show log | inc 1/0/28
16w1d: %LINK-5-CHANGED: Interface GigabitEthernet1/0/28, changed state to administratively down
16w1d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/28, changed state to down
16w1d: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/28, changed state to up
16w1d: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/28, changed state to up
sw3750#show spanning-tree int gi1/0/28
Vlan Role Sts Cost Prio.Nbr Type
VLAN0030 Desg FWD 19 128.28 P2p
sw3750#
Do I need the spanning-tree portfast on this port? Could it be causing a problem? What would the effect be from removing it with 'no spanning-tree portfast'?
TIA
Giuseppe Larosa Sun, 09/28/2008 - 10:56
  • Hall of Fame,
    Founding Member
Hello Charlie,
if you remove the spanning-tree portfast the port will go through all the STP states blocking to learning to listening to forwarding for up to 50 seconds.
This can be a problem for a DHCP client.
If your devices have fixed ip address you can remove it.
I would suggest you to have more meaning on the logs to use:
conf t
so you can get the exact date and time of every logged event
Hope to help
Giuseppe
akharmanbiz Sun, 09/28/2008 - 10:12
Maybe the windows client NIC is incorrect configuration
or
you must enter the following commands:
speed auto
duplex auto
IM-Design Wed, 10/08/2008 - 03:59
Thanks for the responses thus far.
I am still seeing this problem and now a shut/no shut does not bring the connectivity back up.
The error counters & CRC counters are not incrementing (that was asked earlier in the thread).
Any further ideas/suggestions for this problem?
serenity001 Wed, 10/08/2008 - 04:58
hi
is this problem happening even if you connect your device to another port ??
IM-Design Wed, 10/08/2008 - 06:04
Have not tried this yet but will do so.
Is there anything I can check via cli that will tell me if there is an unresolvable problem with the port (failure)?
IM-Design Thu, 10/09/2008 - 02:11
Hi serenity,
I reconfigured another port and connected that device to the new port. It seems to work now.
Do I have a failed port?
How can I check?
TIA
serenity001 Fri, 10/10/2008 - 00:19
could you attach the
show interface, show runn interface
for both ports (the one which is working and the bad one)
IM-Design Fri, 10/10/2008 - 02:46
Here is the output from the show run interface and show interface for the 2 ports (28 is not working, 33 is working at present)
power inline never
no mdix auto
no cdp enable
end
sw3750#show interface Gi1/0/28
GigabitEthernet1/0/28 is administratively down, line protocol is down (disabled)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
Last input 6d13h, output 2d20h, output hang never
67899875 packets input, 1342612372 bytes, 0 no buffer
Received 1049949 broadcasts (0 multicast)
0 watchdog, 813606 multicast, 0 pause input
128619844 packets output, 2279668102 bytes, 0 underruns
0 output errors, 0 collisions, 41 interface resets
sw3750#show run interface Gi1/0/33
Building configuration...
Current configuration : 232 bytes
interface GigabitEthernet1/0/33
power inline never
end
sw3750#show interface Gi1/0/33
GigabitEthernet1/0/33 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0018.7393.4aa1 (bia 0018.7393.4aa1)
Last input 1d18h, output 00:00:00, output hang never
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 3000 bits/sec, 6 packets/sec
41227870 packets input, 2854567456 bytes, 0 no buffer
Received 3983 broadcasts (0 multicast)
0 runts, 20 giants, 0 throttles
144906 input errors, 74016 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 3451 multicast, 0 pause input
79260391 packets output, 656040118 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
FWIW, port 28 was previously configured the same as port 33, but it did not work, so I removed spanning-tree portfast since I have multiple devices connected to this port and have read somewhere that having spanning-tree portfast on the port can cause loops which could bring down the whole network. Also from what I understand the 'no cdp enable' and 'no mdix auto' statements are inconsequential.
Can you spy anything in the show interface output that looks suspicious?
Is port 28 a failed (bad) port?
TIA
serenity001 Sat, 10/11/2008 - 10:14
hi
spanning-tree portfast command is used when you the port is connected to a host (desktop, phone ,access point) as you know each port gos in to five stages till it reach the forwarding stage and this will take around 50 sec.
so portfast will fores the port to go directly into forwarding stage.(this is useful for the DHCP)
cdp ( cisco Discovery Protocol) this can be used to check if you have any cisco equipment connected to your switch/router
you can use show cdp neighbouer will help u
now what is the point from this command
power inline never
regards
Amit Singh Sun, 10/12/2008 - 21:39
  • Cisco Employee,
It looks like on port 33, you have hardcoded the speed and duplex. While on port 28 it was set on Auto-auto. It seemed to be some spedd/duplex negotiation issue with the NIC and the switchport and hardcoding the same has resolved the issue. Try to switch the PC back to port 28 and hardcode the speed/duplex. I would also suggest upgrading the NIC dirvers to the latest one.
HTH, Please rate if it does.
-amit singh
Amit Singh Sun, 10/12/2008 - 21:41
  • Cisco Employee,
This is just from the " show interface output " only. The interface configuration doesnot reveal the same.
