how to copy flash
Answered Question
Sep 27th, 2008
Hi ,
I am trying to copy image from flash from rtr1 to rtr2.. the files is c3745-ipvoice-mz.123-11.T.bin.. and I do not know how to do that. I tried what I know but did not work.. I also wants to delete the old image on rtr2 b4 I can upload the new image to rtr2 since I do not have enoug room to have both images in one rtr.. Thanks for your help
Correct Answer by Giuseppe Larosa about 8 years 7 months ago
you need to make rtr1 a tftp-server for the file image you want to transfer:
rtr1:
tftp-server flash:imagefile-name
rtr2:
delete flash:oldimage:filename
squeeze flash:
copy tftp flash:
it will ask the ip address
then the filename
then where you want to save it
Hope to help
Giuseppe
Overall Rating: 5 (2 ratings)
Correct Answer
Giuseppe Larosa Sat, 09/27/2008 - 08:25
  • Hall of Fame,
    Founding Member
rtr1:
rtr2:
squeeze flash:
copy tftp flash:
then the filename
Hope to help
Giuseppe
cisco steps Sat, 09/27/2008 - 08:48
Thanks Buddy !!!! done , it was easy :-). just an fyi .. I added
boot-start-marker
boot system flash c3745-ipvoice-mz.123-11.T.bin
boot-end-marker
to have a rtr2 reboot after reload
Giuseppe Larosa Sat, 09/27/2008 - 10:02
  • Hall of Fame,
    Founding Member
yes it is needed well done, I focused on moving the file from rtr1 to rtr2
thanks for your kind remarks and having signaled that this case has an happy end
Best Regards
Giuseppe
