ingress queues,frame placement, in layer 2 switch
Sep 27th, 2008
hi every body!
1)i just want to know when a layer 2 switch receives a frame on port, how does it determine in which ingress queue the frame be placed?
is it decided by qos in frame?
thanks a lot!
Prashanth Krishnappa Sat, 09/27/2008 - 20:55
Not all platforms support input scheduling but if your switch does, your understanding is correct. It depends on
1)QoS markings on the incoming packet
2)The queue selected depends on cos/dscp to ingress Q map
Here is some documentation(I picked 3750 for example)
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swqos.html#wp1065146
