CUCM 6.1 on HP DL380 G3
bobsairam Sun, 09/28/2008 - 04:21
You need the dl380 server above 2 GHZ speed to install the CUCM 6.x
Hope this helps * Rate it*
pepsico_anz1 Tue, 09/30/2008 - 22:24
I had a similar issue cos I had 2 CPUs not 1.... make sure you have exactly what is listed, nothing more, nothing less...
maybe post all your server details, piece by piece
dannymeyer Wed, 10/01/2008 - 04:07
Yes, follow carefully what is listed under the G3 model in the cert hardware list page for CUCM and put that parts in. Otherwise it will stop and complain.
Better material doesn't count, amount is important.
