Prefix a 9 to outgoing calls by analog device
Sep 27th, 2008
I have a system where the analog device does not prefix a 9 in the dial string. It dials out using an fxs port on a UC520(CME) 'box'.
The UC520(CME) is configured to require a 9 for outgoing calls. I tried the following so that the voice port would tack on a 9 to the digits but it didn't work:
voice translation-rule 2
rule 1 // /9/
voice translation-profile fax3out
translate called 2
voice-port 0/0/2
translation-profile outgoing fax3out
Does anybody know how I can solve this problem?
Overall Rating: 4 (1 ratings)
Marwan ALshawi Sun, 09/28/2008 - 02:09
try to make the transaltion as following
voice translation-rule 3
rule 1 /\.*/ /9\1/
voice translation-profile fax3out2
translate called 3
voice-port 0/0/2
translation-profile outgoing fax3out2
and this is the virifications for the trnaslation-rule 3
Router#test voice translation-rule 3 123456
Matched with rule 1
Original number: 123456 Translated number: 9123456
the orginal number was 123456
the translated number is 9123456
if the translation wont work u could make a dial-peer that take the call from the fxs and prefix 9 then other dial-peer can handl it
if helpful Rate
and let me know after u try it
aciscolook Sun, 09/28/2008 - 23:18
Thanks for the recommendation. I will try this next chance i get.
I'm just curious why this would work and not the one I had used since the results of the test voice-translation-rule are the same. That's why I have a feeling it won't work.
Your second suggestion seems more interesting....can you spell out an example configuration to do this....if you get a chance.
I appreciate your help.
Marwan ALshawi Mon, 09/29/2008 - 03:17
try the following
i will combine COR list with trnaslation pattren
first the cor list wil make the FXS only have a ccess to a spicific dial-peer that will take the call and then prefix 9 to it
dial-peer cor list FXO-access
member FXO1
dial-peer cor list fxs1
member FXO1
dial-peer voice 9 pots
destination-pattren 9T
port 0/0/1
this one was for outisde calls thorugh ur FXO
now lets make the FXS config
dial-peer voice 91 pots
destination-pattren 1100
corlist incoming fxs1
port 0/1/0
this one configured the fxs port for phone number as 1100 and incoming cor as fx1 created above and this cor list have access to a cor list on the outgoing direction called FXO-access created above as well
dial-peer voice 93 voip
distination-pattren [the called number from fxs u wanna match]
corlist outgoing FXO-access
prefix 9
this one will take the call from the fxs prefix nine after that the final number should match the destination-pattren 9T and exit the the FXO
try it and let me know if worked
good luck
if helpful Rate
