mobile voice access
Sep 27th, 2008
hi
i need to configure mobile voice access, but currently i am using MGCP as the gateway. is it possible to have the gateway registered in both MGCP as well as H.323 with H.323 only for mobile voice access
thanks
ebreniz Fri, 10/03/2008 - 12:51
  • Silver, 250 points or more
If you have two PRIs in the same router then you can use one with MGCP and other with H323, you may add other router to only use H323. it's your choice. you can do it.
PSTN --- GW <-- MGCP --> CUCM
<-- H.323 -->
You use the same GW, just add it as H.323 then configure a Route Pattern for the MVA pointing to this H.323
Under H.323 you create incoming voip dial-peers.
For more information please the following documents
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmfeat/fsmobmgr.pdf
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmfeat/fsmobmgr.html#wp1144476
Sushil Kumar Katre Sat, 10/11/2008 - 16:14
  • Gold, 750 points or more
I guess you have the following two options -
TO run H.323 on the GW because of VXML capability
OR to add another router configured to H.323 for VXML capability
-> Sushil
