2924XL Unable to use console port
Sep 27th, 2008
I recently purchased a secondhand 2924XL switch and I've not been able to get in through the console port. I've not seen any output from it at all with a rollover cable that works fine on my 2600 router.
So far I have tried:
Using every speed from 115200 to 110
Hardware flow control on, and off
Xon/Xoff flow control (on and off)
I have been able to telnet in, but that's of little use without the passwords. Is there any other way of resetting it?
synmonger Mon, 09/29/2008 - 04:12
Thank you for the reply! I have tried the password recovery procedure, but a switch: prompt never comes up.
Prashanth Krishnappa Mon, 09/29/2008 - 05:43
  • Cisco Employee,
If you are sure your console cable/terminal settings is fine, I would suspect a bad console port.
Matthew Warrick Mon, 09/29/2008 - 08:45
Just in case, I would also try and console into a "known good" device with your computer to ensure that it is not your COM port or rollover cable that is bad.
synmonger Mon, 09/29/2008 - 17:12
The rollover cable works just fine on my 2620 router.
