NAC Appliance: how to clear configuration ?
didyap Fri, 10/03/2008 - 08:49
  • Silver, 250 points or more
The Clean Access Manager can be restored to the factory default accounting configuration as follows:
1. Go to Administration > Backup to backup your database before restoring default settings.
2. Go to User Management > Auth Servers > Accounting > Server Config
3. Click the Reset Events to Factory Default button to remove the user configuration and replace it with the Clean Access Manager default accounting configuration.
4. Click OK in the confirmation dialog that appears.
felixjai Sun, 10/05/2008 - 17:14
Let me give you the easiest solution (from a real-world experience). Download the Clean Access ISO from Cisco CCO and burn into a CD. Boot the CAM and CAS servers with the CD and reload the image to the appliance. This process only takes less than 10 minutes for each box. And it's clean and fresh.
