DMVPN Redundancy
Sep 28th, 2008
I would like to know configuration details while configuring DMVPN dual hub redundancy. What are the things need to be checked before configuring DMVPN dual hub scenario?
We are using 2800 series routers with VPN modules. Will it be ok to use these series routers as a hub? (We need 10-15 tunnels max from each hub)
Overall Rating: 4 (1 ratings)
Marwan ALshawi Sun, 09/28/2008 - 05:07
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
10-15 tunnel sounds verynormal
for ur considerations u need to have proper IGP routing like ospf/eigrp or static route between sites tunnels and consider each routing protocols parameters like with ospf u can use cost to prefer tunnel over tunnel while with eigerp u need to consider the use of delay and the split-horizen as well
good luck
if helpful Rate
chinmay.talati Sun, 09/28/2008 - 18:19
Thanks for your valuable reply. I am using EIGRP as a routing protocol and delay as a metric for preference over tunnels.
I will test it and let you know.
Thanks.
Chinmay
