Adding memory to a Cisco 2620?
Sep 28th, 2008
I wnat to upgrade the memory on my Cisco 2620 router. It looks like it has 48mb, is this possible, can you get to 24mb dimms or is it using a 32mb and 16mb?
Does Dimm 0 and Dimm 1 have to be the same size?
Here is my config, I want to get an IOS that supports VPN's, but I think I need around 98mb.
Router#sh ver
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(29b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Mon 30-Jul-07 17:18 by kellythw
Image text-base: 0x8000808C, data-base: 0x81120AC0
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
Router uptime is 2 hours, 13 minutes
System image file is "flash:c2600-is-mz.122-29b.bin"
cisco 2620 (MPC860) processor (revision 0x200) with 45056K/4096K bytes of memory.
Processor board ID JAD05060VMH (1277056474)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Router#sh flash:
System flash directory:
File Length Name/status
1 10323912 c2600-is-mz.122-29b.bin
[10323976 bytes used, 6453236 available, 16777212 total]
