Time of the Day Routing
Sep 28th, 2008
Do the Time periods correspond to server or phone timezone? If I have a soft phone and login to it from a diff timezone than the server time zone,which time is considered?
Appreciate your reply. Thanks..
Overall Rating: 5 (2 ratings)
Marwan ALshawi Sun, 09/28/2008 - 16:39
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
the time that ur phone in the serverr i mean u need to have a device pool and in the device pool u have to have a time zone
if not then the phone time will be considered
if helpful Rate
Chris Deren Sun, 09/28/2008 - 17:12
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
You select the time zone at the parition level, you have 2 options:
use time of Originating Device
or Specific Time Zone
Understanding Time-of-Day Routing
Time-of-Day routing comprises individual time periods that the administrator defines and groups into time schedules. The administrator associates time schedules with a partition. In the Partition Configuration window, the administrator chooses either the time zone of the originating device or any specific time zone for a time schedule. The system checks the chosen time zone against the time schedule when the call gets placed to directory numbers in this partition. The Time Period and Time Schedule menu items exist in the Route Plan menu under the Class of Control submenu. The Partition and Calling Search Space menu items also have moved to the Class of Control submenu.
HTH,
Chris
Marwan ALshawi Sun, 09/28/2008 - 18:33
Chris this is 5+ ..
Marwan ALshawi Sun, 09/28/2008 - 18:34
Chris this is 5+ ..
