Troubleshooting QoS on a 3825
Sep 28th, 2008
The topology: (hopefully my ASCII drawing formats correctly)
[IPTube]-<vlan11>-[2970]-<vlan11>-[3825]-<vlan42>-[1811]-<vlan31>-[IPTube]
The IPTubes are from Engage and are TDM to IP devices that have been configured to mark packets with ToS 0x08 (DSCP 2).
The problem:
In the 3825 -> 1811 direction, I can see DSCP 2 out VLAN31 - no problem:
3825#show policy-map int vlan42 output
Vlan42
Service-policy output: IPTube
Class-map: IPTube (match-all)
256763715 packets, 159450264603 bytes
5 minute offered rate 1655000 bps, drop rate 0 bps
Match: dscp 2
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 2000 (kbps) Burst 50000 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: class-default (match-any)
554345 packets, 319306444 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
1811#show policy-map interface vlan31
Vlan31
111002338 packets, 68932451910 bytes
Match: dscp 2
Queueing
Strict Priority
10599 packets, 635940 bytes
Match: any
In the 1811 -> 3825 direction however, I see DSCP 2 only as far as the vlan42 SVI facing the 3825. The 3825 doesn't seem to see the DSCP marking:
1811#show policy-map interface vlan42
Vlan42
111036374 packets, 68953588269 bytes
5 minute offered rate 1656000 bps, drop rate 0 bps
Match: dscp 2
Queueing
Strict Priority
1584 packets, 224640 bytes
Match: any
3825#show policy-map interface vlan11 output
Vlan11
0 packets, 0 bytes
Match: dscp 2
Queueing
Strict Priority
565011 packets, 31043926 bytes
Match: any
Anyone see anything fishy in the configs or in the software versions that might explain this?
SW versions:
3825: 12.4(10) (Advanced IP Services)
1811: 12.4(6)T11 (Advanced IP Services)
Configs:
! 1811
interface FastEthernet9
description ** TLS to 3825
switchport access vlan 42
interface Vlan42
ip address 10.79.253.6 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip tcp adjust-mss 1412
service-policy output IPTube
class-map match-all IPTube
match dscp 2
policy-map IPTube
class IPTube
priority 2000
! 3825
interface FastEthernet0/1/0
description ** 2970
switchport mode trunk
interface Vlan11
ip address 10.79.11.250 255.255.255.0
match dscp 2
policy-map IPTube
class IPTube
priority 2000
