satish_zanjurne Sun, 09/28/2008 - 20:26
  • Silver, 250 points or more
Below commands would be useful..
"show interface "
"show ppp multilink "
HTH...rate if helpful..
ciscotac1 Wed, 10/01/2008 - 20:23
I'm looking for something similar to showing the bits or bytes per second rate used by the whole mlppp link. Will the two commands give me that information? :)
Scott Cannon Wed, 10/01/2008 - 22:26
Defintely. You will be able to see the last 5 minutes of usage in the router.
Beyond that, I recommend an analayzing tool that will correlate this data into a database and allow yo uto use it for historical reporting.
I've used various tools to do this - check out MRTG.
Cheers
Scott
