Creating tunnel between two end point
mahesh-gohil
Dear All,
I need config support for establishing a tunnel
RouterA--PE--My Cloud--Internet Cloud--RouterB
I want to create tunnel between RouterA and RouterB. Ultimately it is tunnel between two router connected via Internet
Hope you understand my requirement
As it is internet so remember I have option of static or BGP only
Please help
Mahesh
satish_zanjurne
Level 4
Level 4
Find below IPSec Tunnel configuration.
Router A
crypto isakmp policy 10
encryption aes 256
authentication pre-share
*****preshare for opposite peer w.x.y.z*******
crypto isakmp key cisco123 address w.x.y.z
crypto ipsec transform-set aesset esp-aes 256 esp-sha-hmac
crypto map aesmap 10 ipsec-isakmp
set peer w.x.y.z
set transform-set aesset
match address acl_vpn
interface FastEthernet0
description***outside/wan interface*****
ip address a.b.c.d x.x.x.x
crypto map aesmap
***set static route to RouterB LAN*******
ip route x.x.x.x x.x.x.x FastEthernet0
*****set encrypted traffic from RouterA LAN to RouterB LAN*****
ip access-list extended acl_vpn
permit ip x.x.x.x 0.0.0.255 x.x.x.x 0.0.0.255
Router B
______________________________________________
crypto isakmp key cisco123 address a.b.c.d
set peer a.b.c.d
ip address w.x.y.z x.x.x.x
crypto map aesmap
****set static route to RouterA LAN*****
****Set encrypted traffic from RouterB LAN to RouterA LAN*****
HTH...rate if helpful..
Marwan ALshawi
u need at leat one public IP addres if two better
and just configure IPsec vpn site-to-site
which is secure and dose the job for u as wanted
for config have a look at the folloing link:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080094634.shtml
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00801dddbb.shtml
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080093f86.shtml
good luck
if helpful Rate
Ok let me work on it . will rate it later
Thanks Guys
Bye
mahesh
