syslog with separate filenames
Sep 28th, 2008
scenario;
i have some 6 FWSM's in separate 6x6500 core switches..
requirement;
i need to log messages on my ACE "permit ip any any log" with separate filenames on a syslog server. how would my syslog config looks like.
cfajardo1_2 Mon, 09/29/2008 - 10:39
sorry for not being so clear...
what i mean is the config on the FWSM
The platform makes no differnce, the fact it you configure the FWSM to send the syslogs to another device = syslog server.
In the syslog server you configure what you need.
You cannot tell the fwsm that you want the remote files to be saved in a particular format or with a specific name.....it just sends the syslog.
HTH>
cfajardo1_2 Mon, 09/29/2008 - 23:14
so how could we distinguish the logs from different fwsm
cfajardo1_2 Sat, 10/04/2008 - 01:58
i know that we have tp do simething on the syslog server.. what iam asking is the fwsm configuration.
Yes - you can configure your nework devices to use "differenet" facility numbers, so your syslog server knows which device type is sending the syslog. it facility 17 is a firewall, facility 10 is a router.
BUT you STILL have to configure your syslog server to log the information by device name/ip address etc.
This cannot be done in the network device.
HTH>
