09-28-2008 09:46 PM - edited 03-15-2019 01:35 PM
I have just finished installing CME 4.0 on 2821 router... All the phones are registered and working properly. The problem is that I an unable to see call log on 7960 phone only. Call log list appears empty on 7960 while it appears ok in all other phones. Any ideas that can help ?
Sheeraz
09-29-2008 07:44 AM
What phone load are you using on the 7960s? Make sure it's not an old version. Also, have you tried resetting the phones and trying again?
09-29-2008 07:35 PM
The phone load is 7960-7940 P00303020214. I have tried rebooting the system several times but problem remains.
Sheeraz
09-30-2008 06:19 AM
Are you by chance using overlay buttons? If that's the case I think the missed calls are only displayed on the ephone that has the ephone-dn assigned to it.
CSCsd58707
Symptom:
Missed calls not reported.
Conditions:
When a DN has overlays configured, any unanswered calls to that particular DN are not reported as Missed calls.
Workaround:
Remove overlays from the DN in the configuration.
