ios upgrade
Sep 28th, 2008
i have a router running the following ios:c3660-i-mz.122-5a.bin.I purchased this ios in order to do vpn:Cisco 3660 Ser IOS ENT/FW/IDS PLUS.Will it be compatible with the 3660 and could it do vpn?
Richard Burts Mon, 09/29/2008 - 03:01
There is not enough information here for us to be able to answer your question. Please post the output of show version so that we can see how much memory and how much flash the 3660 has. This is essential to be able to say whether the new release is compatible or not. It would also help if you would post the file name of the new image so that we can see exactly what version and feature set it is. If we know those things we should be able to answer your question.
kolawole1 Mon, 09/29/2008 - 03:46
the flash is 25165824 bytes.In fact i would like to set up easy vpn at remotes sites and i m looking for ios which could do it.I have about 25 sites each with different routers .How could i easily identify the right ios for this ?
