NAtting Issue
Sep 28th, 2008
I have a L3 swith where user vlan is created & the natting is done in ASA.
In ASA:
nat (inside) 1 10.10.11.0 255.255.255.0
global (outside) 1 210.212.10.x 210.212.10.20 netmask 255.255.255.240
route outside 0 0 x.x.x.y (router interface connected with asa)
route inside 10.10.11.0 255.255.255.0 10.10.20.2 (switch interface ip connecte switch asa inside)
End users are assigned static IP. I don't have internal DNS server. Whenever users want to access internet they need to authenticate in a website which is hosted in internet using username & password & after successful authentication he can access internet. So a public ip is assigned against the ende user from the public ip pool. Is there any way to achieve this using wasting public IP?
Customer is not going for internal DNS...
Please suggest.
dhananjoy chowdhury Mon, 09/29/2008 - 01:35
  • Silver, 250 points or more
For the Public IP issue, what you can do is do PAT instead of using the Public IP pool.
Do this
no global (outside) 1 210.212.10.x 210.212.10.20 netmask 255.255.255.240
global (outside) 1 210.212.10.20
Now, all the inside clients will be using only a single IP , i.e, 210.212.10.20
For the DNS , you can ask the customer to use the free DNS service from OpenDNS.
Put these IP'sas primary and Secondary DNS on thw clients.
208.67.222.222
208.67.220.220
Hope this helps.
